where can i find these?
these are the connxections in the spoiler break light and i wan to know where i can get them>?
probably maplins but need to know what they are called or a part no!
Re: where can i find these?
It's a plug but never seen one like that used outside the car Industor. I would look at RS first, Maplin was the last I looked at.
These are often called LED sockets which is misleading. The only place I can find them is RS Components here:
http://uk.rs-online.com/web/search/sear ... &R=0336110
When I found that some of the holders had rusted away (due to almost inevitable slight water ingress) I just replaced them all with directly soldered in LEDs of suitable colour temperature together with series resistor on each one. Should never have blown bulb again.
simmilar to what im doing got the leds that have the resisters in them and poluged them in but im doing a how to on replacing the full board so wanted to know where to get em
cheers!!!
cheers!!!
When mine was repaired a while ago...my mate just took the bulbs out of the holders and bent the bulb wires so that they went through the circuit board holes, secured with a dab of solder...sorted.
SE9
Gordie did you ever sort out that rear brake light hope it didn't take too long to do, I did mine in a couple of minutes with the use of one of these.
http://cgi.ebay.co.uk/REAR-BRAKE-STOP-L ... 0664937586
Best Presented Billing 2009
Best Interior Billing 2010
Flooded out 2012
Best Interior 2014
Flooded out 2012
Best Interior 2014
Best not let ally see that Norrie
v6 steve wrote:Best not let ally see that Norrie
always good to see someone get a bargain cough "red roose hoses" cough
edit - bought one for a spare
