Ecotec Cooling Fan - Is it the same as any other Vauxhalls?
I need the connector that plugs into the cooling fan, as some previous owner saw fit to cut ours off when bodging/fitting a replacement fan, which has since died
I've got a proper ecotec replacement fan, but there's no plug on the end of the cable to hook it up.
Is it part of the main loom? and is it the same as any other vauxhall, eg vectra's etc?
If its the same as any other Vaux's, i'll nip down the scrappy and see if i can find a car to cut one off!
§torm
Re: Ecotec Cooling Fan - Is it the same as any other Vauxhal
yes you'll find the same connector on the vectra with the XEV engine
