D.i.y air filter
D.i.y air filter
Thinking about making a panel filter for the air box there's loads of foam sheets on ebay not sure what type to make it from any idears
Rocket
Re: D.i.y air filter
why? do what is suggested here bud for the airbox! same as all the other calibras
http://www.v6calibra.net/tuning/v6_calibra_tuning.htm
You'd also need to make a tight seal round the airbox with your DIY filter.
For the cost of a Pipercross panel, approx just over £30, a DIY isnt really worth it.....IMO of course.
you can buy calibra ones without any problam, i cant see why you would make or use an other cars, iv a K&N cone with heat sheild and cold air feed it sounds the dogs
Just got an k&n panel filter going to run a cold air feed to the std air box does any body know what size the air intake is on the air box for a c20xe
Rocket
