Can you guess
Can you guess
by Callyman » Fri Aug 05, 2011 7:32 pm
What I was doing this afternoon?
Re: Can you guess
by bodgetastic » Fri Aug 05, 2011 7:36 pm
Superman fitted you a new intercooler?
Re: Can you guess
by Callyman » Fri Aug 05, 2011 7:39 pm
I thought someone might mention Superman (it's Daniel my eldest).
No, not that Steve (you know what i was doing)
Re: Can you guess
by bodgetastic » Fri Aug 05, 2011 7:46 pm
Im guessing you found a boost leak then?
Re: Can you guess
by Callyman » Fri Aug 05, 2011 7:50 pm
Didn't find one no, but have cured it. :band:
I removed every hose, rebuilt the entire system end to end and double clamped (where room) every joint.
Boost has now crept up 1-2 psi and is making no squealy whistling noises as before.
5 hours work but worth it, as not only is it fixed, but each joint is hugely stronger that it was before.
Re: Can you guess
by v6 steve » Sun Aug 07, 2011 5:08 pm
Andy your leak might be coming of the left hand side pipe it looks a bit loose :lol: does Jane know where her curtains are
Re: Can you guess
by BazV6er » Tue Aug 09, 2011 1:54 pm
good work mate lol for a minute then i thought you did a spray job hence the sheet behind the bumper lol
