anyone local spare part needed
hi
i live in over cambridge and need a fuel feed pipe for my car just woundered if anyone was available tonight to either lend me one or i will buy of you, need to try and get my car running again so i can see if its ok to put through an MOT.
thanks lynette
thanks lynette
lynettetink
Re: anyone local spare part needed
do you mean the part that is mounted to the top of the fuel tank???
no its the part that connects the fuel pipe to the engine.
cheers lynette
cheers lynette
lynettetink
you should be able to use a rubber hose a jubilee clip
the metal pipe with the screw on union you mean
Hi Lynette.
I am based in the Bedford area, if you want I may be able to come over tomorrow to see what we can do.
Regards
John
Regards
John
jonthevauxhallman
hi, thanks for the replies think im sorted now got some pipe so gonna have ago at that while i wait for the proper pipe to be delivered. its just to see if there is any other problems to sort out before i put it through an MOT.
thanks lynette
thanks lynette
lynettetink
right, now i need to ask if there is anyone in the cambridge area who has a decent scrap calibra that they dont mind me taking some bits of for my car. as there is no scrap yards that have a calibra in.
thanks lynette
thanks lynette
lynettetink
You can use Cavalier, Astra mk3 and even some Vectra parts... depends what you need really. There are a lot of shared parts across the range
most of us have quite a lot of spares kicking aorund, what specifically do you need?
