Metal polishing
Metal polishing
has anyone done it before ?
i bought a polishing kit and have watched some you tub video's, i'm not sure if i'm just not patient enough but i cant get the results that they get,
any pointers ?
any pointers ?
Re: Metal polishing
iv done a bit i use a dremmel and t cut
Re: Metal polishing
I did it on my accumulator pipes.
Best to use wet n dry to get it as smooth as poss first.
Re: Metal polishing
wet and dry till totaly smooth then start working down the grades of waxes with the appropriate mops takes a long time remember to use lime powder also to clean waxes of between stages
i did my rocker covers on skyline and took almost a week to get perfect
Re: Metal polishing
Dont forget a light coat of lacquer if polishing steel.
Re: Metal polishing
i spent and hour doing one side of my header tank and it looks s**t, not sure if its worth the hassel does's anyone know of anyone that will do it for beer tokens?
Re: Metal polishing
Re: Metal polishing
started with brown then went to blue for the last stage
Re: Metal polishing
How long did you do it for? it can take ages
Re: Metal polishing
think it was an hour on one side which will only be 100mmx150mm
