Sprung a leak
Sprung a leak
The rubber base of my aerial has decided it wants to be in 2 bits and in this rain is leaking into the roof lining which had
dropped at back from the last time i changed it. I was wandering if i should spend the £60 for a new Vaux one or buy one of
these from ebay that doesn't have the rear washer bit and use the rubber bit from this. Anyone else done this?
http://www.ebay.co.uk/itm/AMPLIFIED-ROO ... 45f235b241
Re: Sprung a leak
got one from LMF last time think it was about £17 , or the evctra one fits as well
Re: Sprung a leak
Didn't realise the vectra one had the washer bit in it, will give them a try, cheers
Re: Sprung a leak
Autovaux do them cheaper than stealers too....ive bought a couple from them.
That rubber seal sure is a naff quality part....I nearly fitted a sharkfin last time but wanted to keep my rear washer.
Re: Sprung a leak
Such a Pest of a Job, for such a Small Part...
I've removed this part recently, and re-done my roof lining, so if you have any questions...
Seeing as your Roof Liner also needs attention, it's an ideal time to also check out the Sunroof components!
Re: Sprung a leak
Sunroof is fine, done this fix a few times and its only just a bit damp on the rear edge of the lining
Re: Sprung a leak
tazz666 wrote:get to a scrappies Rob
They'll all be knackered at the scrappies....the rubber seal starts to split/perish after about 12 months.
Re: Sprung a leak
MadOnVaux! wrote:tazz666 wrote:get to a scrappies Rob
No decent scrappies around here anymore
Re: Sprung a leak
New base from Autovaux fitted today, all sorted now, except i think the washer nozzle is a bit bent as when i squirt the window the water jet hits the rubber seal at the top of the window and only just dribbles down
Re: Sprung a leak
you should be able to move the nozzel with a pin
Re: Sprung a leak
will give that a go sometime when its warmer
Re: Sprung a leak
Remember to adjust it so it just and so squirts on the screen at the top, as when your driving it it'll squirt lower down due to airflow....adjust it too far down when it's stationary and it ends up missing the glass altogether.
