front and rear subframe
by rich30mex » Tue Apr 03, 2012 11:42 am
Have all calibras got the same sub frames or did they different ones to different models ie is the turbo 4x4 one the same as the v6 ecotec and redtop
Re: front and rear subframe
by Allys Cally » Tue Apr 03, 2012 12:42 pm
if i remember rightly the rear subframes are all the same, its only the turbo front subframe thats different due to the transfer box.
if i'm wrong no doubt i'll be corrected :lol:
by KERR_SE9 » Tue Apr 03, 2012 12:57 pm
You're right turbo is the only different one
by Fraz » Tue Apr 03, 2012 2:12 pm
though the trailing arms will have 5 stud hubs for turbo and V6 and rear brakes I think may also be a different size ...could just simple swap the rear arms though
by v6 steve » Tue Apr 03, 2012 5:49 pm
im 99% sure the rear is the same apart from the hubs but you can fit the 4x4 diff and drive shafts to a 4 stud if you wanted
