V6 Air Con
V6 Air Con
by SE9V6 » Fri Jun 08, 2012 8:28 pm
does any1 know where the low side port is situated, as i have just bought an all in 1 air con service in a can. it comes with a reusable trigger activated pressure guage/nozzle. The instructions say it has to be connected to the low side port to recharge the system as connecting it to the high side port(which sits between the battery and the engine) can cause the can to explode. i have looked all round for the low side port and can't find it anyway
thanks
Re: V6 Air Con
by Fraz » Fri Jun 08, 2012 8:57 pm
its on the pipe that runs along the subfarme drivers side
Re: V6 Air Con
by SE9V6 » Fri Jun 08, 2012 9:00 pm
thanks fraz,
is that the one that disappears underneath the compressor?
Re: V6 Air Con
by Fraz » Fri Jun 08, 2012 9:43 pm
yes and usually the one thats needing changed as heat from the exhaust makes it leak
Re: V6 Air Con
by SE9V6 » Fri Jun 08, 2012 10:27 pm
awesome, thanks alot. don't think mine is leaking at the minute, so fingers crossed it won't after it's been disturbed.
