Compression test on the se2
by Jamesyboy » Thu Dec 27, 2012 11:14 pm
Just done a test for pure curiosity....
1st cyl 11.5 bar
2nd 11 bar
3rd 11.1bar
4th 12.6 bar
opinions on cylinder 4 please :-)
Re: Compression test on the se2
by Jamesyboy » Thu Dec 27, 2012 11:42 pm
i just read the instructions again.... it says with throttle open.... whoops, would that make a difference?
by Jamesyboy » Fri Dec 28, 2012 12:09 am
yea i know, we held it until a steady reading was there, ill do it again tomorrow.... im only doing it out of curiosity to see whats going on in there :D
by Fraz » Fri Dec 28, 2012 12:13 am
and did you take all 4 plugs out at the same time or just one at a time ?
by Jamesyboy » Fri Dec 28, 2012 12:14 am
just one at a time
by bodgetastic » Fri Dec 28, 2012 12:36 am
Jamesyboy wrote:Just done a test for pure curiosity....
I can tell you from years of experience, 'out of curisoity' checks on a turbo will lead to long sleepless nights :lol: :lol:
Put the compression testor on a high shelf :whistle:
by Jamesyboy » Fri Dec 28, 2012 12:43 am
:lol:
by craigyboy » Fri Dec 28, 2012 3:25 am
Good results mate :clap:
by GreyDJ » Fri Dec 28, 2012 1:20 pm
I'd be spinning the engine with all the plugs out.
Given that it is measuring the pressure in the cylinder with the valves closed not in the inlet tract, why would the throttle position make any difference?
Were the tests run dry or with oil in the cylinders?
Cavalier CDi 96 Grey
Cavalier SRi 93 Satin Red
Cavalier Mk2 CD130 86 White
by Callyman » Fri Dec 28, 2012 1:34 pm
The throttle being open (only reason i can think of) is so when the piston drops and inlet valve is open the chamber will get the max amount of air possible (therefore better compression the more air you get) if the throttle is open.
Just a thought.
by GreyDJ » Fri Dec 28, 2012 1:38 pm
OK.
I have always run the test with it closed but as the conditions are the same for all cylinders a comparative test between them should be valid.
by GreyDJ » Fri Dec 28, 2012 1:49 pm
Yes, I suppose with everything cold the air going in is much denser than in a running engine with hot inlet tract.
by Fraz » Fri Dec 28, 2012 3:14 pm
GreyDJ wrote:I'd be spinning the engine with all the plugs out.
you would do a wet test after getting a low reading
by GreyDJ » Fri Dec 28, 2012 3:25 pm
Out of curiosity I do both tests if I get more than about 5% difference, it doesn't take very long and I use Redex not oil on a cat'd engine. I would certainly do both with those figures, you would normally expect one to be low, not high.
