Another year out the way
by craigyboy » Fri May 03, 2013 6:31 pm
Passed its mot today :dance:
Only been advised about the head lights.Can they be converted
for the beam to face to the left?
Re: Another year out the way
by Fraz » Fri May 03, 2013 6:55 pm
on original headlights there is a small leaver to change Left to right ..do not know about aftermarket ones
by v6 steve » Fri May 03, 2013 7:27 pm
:clap: its always a good day when they pass
by Allys Cally » Fri May 03, 2013 7:49 pm
Fraz wrote:on original headlights there is a small leaver to change Left to right ..do not know about aftermarket ones
i'm sure you can change them iirc, been that long since i had the angel eye lights so i'm not 100%
by Phill » Fri May 03, 2013 8:31 pm
Well done mate. :clap:
by craigyboy » Fri May 03, 2013 10:09 pm
He said if I still have them on next year he
will fail it :roll:
by Fraz » Sat May 04, 2013 8:13 pm
I would have failed it ...are they aftermarket ones you have ??
from the tester manual
Headlamps Reason for rejection
1.
A headlamp which does not conform to diagrams 1, 2 or 3 that has a beam image which is aimed so that it dazzles other road users.
2.
Projected beam image obviously incorrect, e.g. where the headlamp bulb is incorrectly fitted or the reflector is seriously corroded
by craigyboy » Sat May 04, 2013 9:21 pm
They are Sonar and i'm gony try to adjust them
to suit
by KERR_SE9 » Sun May 05, 2013 12:33 am
Are you an mot tester fraz?
by Fraz » Sun May 05, 2013 1:46 pm
KERR_SE9 wrote:Are you an mot tester fraz?
I was ...why you looking for a dodgy MOT ?
by KERR_SE9 » Sun May 05, 2013 6:17 pm
Ha fat chance, I get beasted for MOTs every time, with regards to you "failing" it, just wondered!
by Fraz » Sun May 05, 2013 6:50 pm
KERR_SE9 wrote:Ha fat chance, I get beasted for MOTs every time, with regards to you "failing" it, just wondered!
I said "I would have" past tense ...and I get on great with computers!!
by craigyboy » Sun May 05, 2013 10:53 pm
Oh the encourgemt :whistle: or which ever way its spelt
by Fraz » Sun May 05, 2013 11:14 pm
encouragement for what
