V6 Diagnostic port
V6 Diagnostic port
by SE9V6 » Sun May 05, 2013 12:55 am
I have the really frustrating issue of having my engine management light keep coming on and have no idea what is causing it!
As it is impossible to get a reading on a diagnostic scanner, as all the contacts inside the plug that connects to the scanner are heavily corroded.
there are 7 wires that go into the plug, but inside, there is only contacts in 5 of the holes, 4 of which are so badly corroded they are black.
What i really need to know is wether or not this plug is unique to the Calibra SE9 V6, or if any other model had the same one?
Any info at all would be a great help, as i am desperate to rectify this problem and feel like without having access to any fault codes i could spend forever and a shed load of cash trying!
Re: V6 Diagnostic port
by craigyboy » Sun May 05, 2013 10:14 am
I had the same problem a few years ago mate.I managed to
get another diagnostic plug from a breakers.Just cut ,join and
solder the cables core for core and then give the plug a smear
of vaseline to stop it corroding
by SE9V6 » Sun May 05, 2013 11:23 am
thanks for the link and info, very useful and hopefully will be alot of help.
altho, i am not so sure that even that will work due to the contacts inside my plug being corroded, as is seen in the pics :think:
diag plug holder (640x480).jpg (101.37 KiB) Viewed 7219 times
diag plug bottom (640x480).jpg (91.6 KiB) Viewed 7219 times
diag plug top (640x480).jpg (120.04 KiB) Viewed 7219 times
by SE9V6 » Sun May 05, 2013 11:28 am
craigyboy wrote:I had the same problem a few years ago mate.I managed to
i have found some1 with another plug, but its still on a complete loom which he won't split, and wants 50 quid for the whole thing!
i originally thought it was on the ECU loom, which he only wanted 40 quid for, and i was gonna go get it and swap the whole lot, as i am almost 100% certain that i have a wiring issue to the air flow meter aswell, so would have been worthwhile, but seeing as the diag plug is on the loom that goes behind the dash, which i dont need, dont really fancy shelling out 50 just for the plug!
by v6 steve » Sun May 05, 2013 1:06 pm
the 1st pic is just a holder it has no use the plug is only for linking to computers ect, i would just find a calibra in a scrapy and cut it off and refit as Craig has suggested
by v6 steve » Sun May 05, 2013 10:45 pm
31 will show up if the engine isnt running
by SE9V6 » Mon May 06, 2013 9:12 pm
v6 steve wrote:31 will show up if the engine isnt running
but it won't if the engine is running?
by Fraz » Mon May 06, 2013 9:50 pm
if the engine is running then you should not get code 31 ..as the crankshaft is turning
by craigyboy » Mon May 06, 2013 10:15 pm
Mate ive got a plug lying in my garage,let me know if you want
it and I could post it to you
by SE9V6 » Tue May 07, 2013 12:35 am
Fraz wrote:if the engine is running then you should not get code 31 ..as the crankshaft is turning
ok thanks mate,
so i take it, if i still get code 31 when the engine is running, then the crankshaft sensor has a fault?
by SE9V6 » Tue May 07, 2013 12:45 pm
ok thanks mate,
so i did the test again with the engine running!
but, it seems as if the process of flashing out the codes gets interupted, and starts over again, and this keeps happening again and again :evil:
during the flashing of the codes, it looks alot like the EML flickers, either in between each flash or during a flash!
with the engine of i get 1,2-1,2-1,2.........1,4,5-1,4,5-1,4,5.........3,1-3,1-3,1.....then back to the start
with the engine running it dont even get to complete the 1,2-1,2 part on most attempts, and on odd occasions it gets about halfway thru the 1,4,5-1,4,5 part.
would this suggest that the crankshaft sensor has a fault????
cheers
Ash
