V6 cams
Re: V6 cams
I think they're the same so a straight swap if you have a later v6 (same engine as a vectra just a different inlet manifold) however if they're camshafts from a vectra b gsi then the inlets will give you a bit more power further down the rev range
. I've got inlets from the gsi but I think the exhaust camshafts are the same, I could be wrong though lol.
Re: V6 cams
Most people just get the two inlet 'G' cams from the X30XE, have heard of some people fitting four 'G' cams though.
Here is a chart for the cams, and what is fitted to what...
Here is a picture showing where the identification letter is stamped on them
I used to own this Calibra...
I now own this one.
Xbox live gamertag IcedSage
I now own this one.
