xev to c20xe
xev to c20xe
hi peeps just thought id ask advice ahead of time,
whats the main difference when swapping x20xev to c20xe ie loom set up etc.. all advice is appreciated and also anything i can do to help boost performane or owt while getting fitted? cheers tosh
Re: xev to c20xe
You just change the engines loom (between engine and ECU). It's literally plug and play in the drivers footwell area.
You can use either engines' gearbox. Shafts and mounts stay the same.
Re: xev to c20xe
i was thinkink that myself but then some one had there 10pence worth while ear wigging an said summat about 3 wires been different or summat
Re: xev to c20xe
Which 3 wires?
Do you have the XE engine already? If so you can just check yourself, I'll explain
Re: xev to c20xe
i do but its in lock up and loom in boot of car in another
