compresion figures for a good c20let
by rich30mex » Wed Dec 03, 2014 1:22 pm
Right I'm about to do some work on the le engine box out subfames off and cleaned and powder coated but don't no weather to do a full engine rebuild so my intention is to take the compressions on each cylinder and see what I'm running at
My question to you guys is what am I looking for on the compression readings
Also what are your thoughts full rebuild while out or leave it if I'm getting good figures
Re: compresion figures for a good c20let
by craigyboy » Wed Dec 03, 2014 6:59 pm
I would leave it Rich if your getting good figures,It will save
you a lot of expense.
by rich30mex » Wed Dec 03, 2014 7:07 pm
craigyboy wrote:I would leave it Rich if your getting good figures,It will save
I'll test at the weekend and report back thanks guys
by Callyman » Wed Dec 03, 2014 8:44 pm
^^ This.
If it ain't broke, don't fix it.
:D
by rich30mex » Wed Jan 07, 2015 2:45 pm
Right just done a compression test on the turbo and got these readings after turning the car over for 10 seconds on each cylinder
Number 1 = 185 psi
Number 2 = 185 psi
Number 3 = 170 psi
Number 4 = 190 psi
Do these sound about right for a c20let with 133k miles on it
Thanks
by rich30mex » Wed Jan 07, 2015 3:02 pm
Thanks
Just out of curiosity does anyone no the figures when the engine was new
by rich30mex » Wed Jan 07, 2015 3:33 pm
Thanks
