Tailgate glass removal
Does anybody know a sure proof means of removing the glass intact from the tailgate? The so called glass "specialist?" managed to remove mine in pieces but I have another in a donor car. I'd just like one less issue...
thanks
thanks
Re: Tailgate glass removal
I'd be interested if you find a way,as I'm certain they break nearly all the time
Thanks. Not what I wanted to hear though
Think you have just been unlucky I had my removed without it breaking and so have a couple of other members by the same person
Allys Cally wrote:Think you have just been unlucky I had my removed without it breaking and so have a couple of other members by the same person
the boy across the road from me did mine Allys and Mr C's with out breaking its not the easiest of jobs deffo one for some one with patience
Thanks for the replies...
I have a good painter but his suggestions for correctly removing bonded glass leave me
Can anyone confirm the method?
@v6steve, you mentioned a good deal of patience is required so can I assume this is the traditional heat/cut/heat approach?
(Congratulations also on achieving that milestone
I'm considering not removing the glass from the one from donor car and just using that tailgate as is. The window surround was in perfect condition on my tailgate so I'm beginning to contemplate (read panic) the implications if this one breaks.
cheers
)I'm considering not removing the glass from the one from donor car and just using that tailgate as is. The window surround was in perfect condition on my tailgate so I'm beginning to contemplate (read panic) the implications if this one breaks.
cheers
Feed a metre of cheese wire through a hollow needle, use the needle to pass through the bonded section, then use the cheese wire in a sawing motion to cut the bond.
Chavtastic thanks for your reply but I suspect the many 100's of cycles of high temps over the years have hardened the bonding material to the extent that it now resembles plastic. Unless I can find something that will soften it significantly or better dissolve it?
cal16v wrote:Chavtastic thanks for your reply but I suspect the many 100's of cycles of high temps over the years have hardened the bonding material to the extent that it now resembles plastic. Unless I can find something that will soften it significantly or better dissolve it?
It's just like cutting through dried silicone
I've done it twice this last month or so in lightening my bootlid
