Steering Rack
Steering Rack
Been out fixing my car all day fitted new track rod arms and ends,wishbone bones,strut top bearings etc and noticed something weird with the engine running all weight back on all four wheels i turned the steering hard lock left and right and noticed the bulkhead flexing in and out is this normal i have never noticed this before
'Once Driven Forever Smitten'
Re: Steering Rack
there is a bit of movement but if you have excess movement it might be that your bulkhead is rotted or thr rubber bushes and gone
Re: Steering Rack
v6 steve wrote:there is a bit of movement but if you have excess movement it might be that your bulkhead is rotted or thr rubber bushes and gone
would say 15 / 20mm movement not sure if that good or bad
Re: Steering Rack
Re: Steering Rack
Cheers for the heads up i really hope mine aint like that be arsed with all the cutting and welding
Re: Steering Rack
I didn't really have much choice to be honest. I was already committed because I'd just bought a v6 engine, box and full 5 stud set up with brakes and suspension for it
