FRONT PASSENGER LEG
FRONT PASSENGER LEG
by Supper » Sat Jun 02, 2018 9:29 pm
Hi does anybody know were i can get a passenger side front leg for a v6 calibra. The bearings in mine as spun inside the leg. Thanks
Re: FRONT PASSENGER LEG
by rich30mex » Sat Jun 02, 2018 9:35 pm
it comes away all i one mate then press the old bearing out and the new one in
remove the track rod end from the leg then split the ball joints at the bottom the remove the large nut in the engine bay at the top it should lift straight out then
by Supper » Sun Jun 03, 2018 6:43 pm
The problem i have is that the bearing has siezed and has spun in the leg,were the bearing fits in. The new bearings i have are now loose.
by STEVA » Sun Jun 03, 2018 7:56 pm
Do you have the right bearing as the 4 stud bearings are smaller than 5 stud bearings
As this happened to me when I did mine
Users browsing this forum: No registered users and 82 guests
