fault codes
fault codes
by Phill » Thu Dec 17, 2020 8:08 pm
Hi all, can anyone put a link up to the list of fault codes that was on the site. I'm think it was vexorg that posted it, I have had a look and can't seem to find it.
Also, can anyone put a link up for the plastic fuel line that some have used to replace the standard fuel pipe.
Thanks.
Re: fault codes
by Cliff » Tue Dec 22, 2020 6:56 pm
Unfortunately, top buzz seems to have been taken down or expired
Luckily I found a print out I took and stored as PDF.
I’ll try to find a way to rehost this info but until then, i hope this helps.http://cloud.tapatalk.com/s/5fe2334dd3c96/fault_codes.pdf
Re: fault codes
by Phill » Tue Dec 22, 2020 8:37 pm
Cliff wrote:Unfortunately, top buzz seems to have been taken down or expired
The links not working Cliff, thanks anyway.
Re: fault codes
by Cliff » Tue Dec 22, 2020 8:38 pm
Seems like something is wrong with Tapatalk. PM me your email address and I will email to you instead.
Re: fault codes
by Phill » Tue Dec 22, 2020 8:58 pm
PM sent.
Re: fault codes
by Phill » Tue Dec 22, 2020 9:15 pm
Thanks Cliff, I got the download and its working fine. :D
Re: fault codes
by Cliff » Tue Dec 22, 2020 9:16 pm
Phill wrote:Thanks Cliff, I got the download and its working fine. :D
