Anyone know anything about spraying alloy/intercooler?
Thinking of spraying my intercooler matt black. It's obviously an alloy intercooler, and wondered the following:
A. What do i need to do to prep it?
2. Will it effect the ability for it to cool the air?
2004 Black Evo 8 with blacked out lights. Lookin' mean!
HKS Camshafts and turbo hotside fitted. HKS downpipe and 3" cat by-pass. RR'd @ 401bhp. Target reached!
Re: Anyone know anything about spraying alloy/intercooler?
Leave it alone. Black will not cool as well.
Its unpainted for a reason.
Im sure when Daddycool did his guide for fitting an Evo FMIC he included a section on spraying it but the site has disapeared unfortinately.
Hears the same Fmic I have which someone has had a go at painting .....
http://www.socalevo.net/index.php?option=com_smf&Itemid=37&topic=71169.0
Ive read mixed things about spraying a cooler but you could try something like this....
http://www.eastwood.com/ew-radiator-black-12oz-satin-finish.html
how about getting it annodised ?
If I remember my physics from school right, then both a metal and a black finish have much the same rate of heat transfer. It is colours, especially white, you need to avoid.
In addition to it not being needed technically, I suspect they are not painted due to the extra cost of the process, the difficulty of getting a cosmetically acceptable finish on the fins and the paint layer reducing the space for airflow between the fins leading to lower efficiency or the need for a bigger area of fin.
Cavalier CDi 96 Grey
Cavalier SRi 93 Satin Red
Cavalier Mk2 CD130 86 White
black paint and aluminium doe not transfer heat at same rate...?????the paint would insulate the cooler and reduce its efficiency slightly at the cost of vanity.dont paint it.
k1nty
everyone likes shiny stuff dont they
