need a bit of help for fixing the tigra
Re: need a bit of help for fixing the tigra
how do you know the drains are not blocked if you cant open the sunroof ??? have you taken them off in the boot areaand blew up them to see if they are clear??
get some taclum powder, cover the rear rubber and then was the car....make sure its dry...open boot and if the waters getting past teh seal, the talcum powder will have washed away
i used a special device which sucked up all the water and these are the drain vents on the rear quarter panelswhen you open the boot.and we tipped more water in and they cleared
BazV6er wrote:i used a special device which sucked up all the water
a sponge
there will also be holes up in the sunroof gutters and they will brain down the pillers in tubes and pop out the bottom of the boot, on the calibra there are two gromets that the tubes pop through the tubes can come loss i would think it will be the same on the tigra
lol a sponge no like a homemade turkey baster using a tube and a bottle what we used for draining oil from cooler lol.
Baz, you need to get that sunroof open to know if the pipes are still connected to the sunroof tray.
okay so what steve was saying it cdould be that the pipe that connects down to the pillar could be the cause of the wet pillar.ok we will try getting sunroof open.
BazV6er wrote:okay so what steve was saying
And Fraz and me.
cheers guys we will look into it..
callyman wrote:BazV6er wrote:okay so what steve was saying
And Fraz and me.
did you say that too
v6 steve wrote:callyman wrote:BazV6er wrote:okay so what steve was saying
And Fraz and me.
Kind of, I was about too when Fraz did, and have agreed somewhere since.
