Plasma cutter
Plasma cutter
Has any one got or used on ? I was working on the "Drain" and i used my mates is some bit of kit and think it will be added to the must get list. Its like cutting butter with a hot knife much better than the old grinder or sthil saw
Re: Plasma cutter
Sounds good and probably looks good but how much dosh out of the wallet ?
Re: Plasma cutter
http://cgi.ebay.co.uk/PLASMA-CUTTER-CUT ... 255835b26e
in the welder price range not sure how often i would use it so might be a dear
Re: Plasma cutter
yes they are great we have one in the factory at work ( and no i cant acquire it before you ask
) makes life so much easier cutting flatbar with it.
Re: Plasma cutter
I have access to one, mate they are the BIZ !
Just make sure you have a decent air supply and power!
the painter
Re: Plasma cutter
i use one every day at work they great make life so easy like dear tho, a good heavy duty one will set you back £400
bigdaz1987
Re: Plasma cutter
my mates one is a phase 3 and is some size, iv been looking on youtube and the smaller ones look fine for what i would ever need it for so its on the list, it wont be bought soon as the list is some size. Now if i could convince jill we need it for the buisness
