v6 problems SOS
v6 problems SOS
my dads v6 wouldnt start today thinking it was something daft i checked all the basic stuff battery fuel air then thought well its turning over but doesnt seem to be getting a spark so i pulled out the 1st 3 ht leads 2,4,6 i think and found they were full of oil which cant be good does anyone know what has happend here
bigdaz1987
Re: v6 problems SOS
Sounds like the rocker cover gasket is leaking. I had the same problem with mine just that it was the ht leads at the back.
Re: v6 problems SOS
get they plastic covers changed to a set of vectra v6 metal ones. that will solve the problem
here you go
http://shop.ebay.co.uk/?_from=R40&_trks ... Categories
here you go
Re: v6 problems SOS
Daz the oil wont be the reason it wont start.
When it's cranking does the Management light flash?
Re: v6 problems SOS
callyman wrote:Daz the oil wont be the reason it wont start.
i didnt check bud but if it does what does this mean
bigdaz1987
Re: v6 problems SOS
It means the immobiliser is kicking in, as the sensor (inside steering cowling) cannot detect the chip in the key.
Re: v6 problems SOS
by the way daz i ment the metal cam covers will solve the oil in the plug wells, sorry if this caused any confusion
Re: v6 problems SOS
check the eml as Andy says, also do a paper clip test
Re: v6 problems SOS
looks like a busy day for me tomorrow then the joys of a v6 and it aint even mine
bigdaz1987
Re: v6 problems SOS
have you done a paper clip test on it ? are all the earth wires connected
Re: v6 problems SOS
I know carbon is conductive on its own. But then if you rearrange the molecules its can be either a conductor or an insulator. If i remember back to my science lessons lol
Re: v6 problems SOS
the battery is brand new full of charge checked that we do have fuel pressure not done a paper clip test yet but the management light isnt on and it turning over slow oh and the oil jet black
bigdaz1987
