car was all covered in snow......
....foam
with the weather a bit better the last few days, managed last week to get a start on cleaning the car. So tried out the no touch method ...snow foam as its called...no idea why
then got the wheels to bleed
and after doing all the polish it was looking not that bad
Re: car was all covered in snow......
So do you just spray it on then wait...then rinse Fraz?
Seems a good idea.......
yup you cover the car in thensnow foam and the dirt just falls off...PROVIDED you have some wax on the car already. It won't remove everything but I wish I had taking a picture of the dirt dripping off with the foam ...but it does get rid off all the dust that is settling on the car
mmm, I might have to invest in this kit, as mine has alot of swirling already.
any link as where to buy?
Don't use it, If it dissolves dirt,what do you think it does to the paint?
They use this foam to wash the bus's where I used to work and after a while they require painting!
Essentially a mild T-cut everytime you wash the car
KERR_SE9 wrote:Don't use it, If it dissolves dirt,what do you think it does to the paint?
really are you sure?? or are you not talking about traffic film remover which is what they do use on lorries and fleet bus's..., this is PH balanced and wont even remove the wax on the car ....dont believe me come over and see it working
Highly recommended on www.detailingworld.co.uk
Could have sworn I already posted all this ...oh well
first you do need a pressure washer but can get one quite cheap these days
http://www.argos.co.uk/static/Product/p ... 151062.htm
then you need the foam lance
got mine through detailing world group buy
http://www.detailingworld.co.uk/forum/s ... p?t=183611
but tried the sample they supplied and was not that great so got some no touch stuff from here...much better
http://www.chemicalguysuk.com/product_p/notch.htm
cant beat a bit of hard work lambs wool sponge and 3 bucket method
matty0785 wrote:cant beat a bit of hard work lambs wool sponge and 3 bucket method
heard of the 2 bucket car wash but whats this 3 bucket method
This will be the second year I've been using the snowform and the paint on mine is fine but then I have god knows how many layers of wax and I do mean wax not polish on the car
RobbieV wrote:matty0785 wrote:cant beat a bit of hard work lambs wool sponge and 3 bucket method
1 for soapy water
1 for clean water
and 1 for ice to put the beers in
Allys Cally wrote:RobbieV wrote:matty0785 wrote:cant beat a bit of hard work lambs wool sponge and 3 bucket method
1 for soapy water
1 for clean water
I'm with ally on the 3 rd bucket method but I do remember an other use for 2 buckets
aye i remember Billing last year
3rd is for doing wheels if you are using acid cleaners etc. now u dont want that in the buckets or on the sponges you use for the carpaint work now do you
