calibra shaking
calibra shaking
my calibra is shaking the front end at 80 to 150 kph?. it has new rotors, break pads, cv shafts, tie rod ends, balljoints and wheel bearings. can any one suggest what might be the cause?...
dean91
Re: calibra shaking
Start with getting the tracking looked at and have the wheels balacned, as after all that work on the front something may be out of line.
Re: calibra shaking
Try another pet of wheels if you can, could be any number of things that cause it
Sent from my HTC Wildfire S A510e using Tapatalk
Re: calibra shaking
Check the wheel bolts are tight as well
Re: calibra shaking
check the king bolt on the driveshaft is tight
Re: calibra shaking
frontend tracking re aligned last week, the wheels have been balanced by almost every tyre place in town, cv shaft nuts and wheel bolts done with tention wrench,?.....i put it on stands and took the wheels off, fired her up to 6000 rpm in 5th gear and it started shaking violently...?
dean91
Re: calibra shaking
Engine mounts?
Re: calibra shaking
might have found it.? front left engine mount is a wreck !!. will replace soon.
dean91
Re: calibra shaking
replaced engine mount.... still shaking!!.... not as bad_
when i got the car the right drive shaft balancer was not there ??? can this affect the balance of the new shaft
if so where can i get a new one and what will it cost
dean91
