Body Kit fitted
Body Kit fitted
Found someone to do the recore, Coolex in Notts,, £108 + VAT - taking it up on Wednesday so the 3.2 should be back on the road by next weekend.
Also sorted out an issue I've had with the other V6
At night with the headlights on the main beam would constantly flicker on and off p*****g off oncoming traffic
Thanks to Mr Gibson, a new indicator stalk sorted it!!!! - beer at Billing for you mate
Here's the knackered little fecker!
Re: Body Kit fitted
He's banned from drinking beer at Billing or any form of alcohol.
Re: Body Kit fitted
Mark1 wrote:He's banned from drinking beer at Billing or any form of alcohol.
Do 1
Re: Body Kit fitted
Re: Body Kit fitted
Re: Body Kit fitted
I was on holiday. Your problem is
Re: Body Kit fitted
Re: Body Kit fitted
2nd Cally's radiator has s**t itself in as many weeks FFS!
You would have thought it could at least of waited until I 'd got the first one back on the road
The b****** must know it's Christmas!!!!
Re: Body Kit fitted
First rad into the 3.2!!!
Top tip everyone, remember to put the vent back under the slam panel to connect the alternator cooling duct to BEFORE you put the rad in NOT after!!!
While reconnecting the temp sensor I came across an unconnected cable hanging down
I haven't the foggiest idea what it's for - any suggestions?
Looks like a two core connector on the end
Body Kit fitted
I'll whip the front bumper off at the weekend and grab a pic
What kind of connector goes to the secondary water pump?
Could it be that? (Not that I disconnected that)
The only other thing I can think of is power to the a/c compressor???
Body Kit fitted
You can just see the connector in the middle with it's cable running down the side of the rad
Re: Body Kit fitted
Did you modify the Radiator Fan Switch?
It looks to have been chopped...
Re: Body Kit fitted
I'll try and get a better pic at the weekend
Not touched the fan switch Eddie
Re: Body Kit fitted
Power lead from A/C pump so not an issue
I do need the rad temp sensor though
£41.28 from Vauxhall !!!
Re: Body Kit fitted
LMF or Autovaux you'll get a discount as a member
