Body Kit fitted
Re: Body Kit fitted
Need to try and figure out the part number
I have up to 3 to choose from and parts chap at main stealers can 't say for sure which one it is!
90355878 ( think this is none a /c)
90339414
90462306
90339414
90462306
Re: Body Kit fitted
After market front wings have got to be swapped back to the OE ones as they aren corroding already
Now to find someone who'll roll the arches
Re: Body Kit fitted
Re: Body Kit fitted
Re: Body Kit fitted
Not in a good place this morning!!!:(:(:(
Been chasing a leak on my 3.2 Calibra ever since I put the re-cored rad in and think I've reached the conclusion it's the rad so it has to come out again at the weekend.
So taxed the 3.0 Calibra for today having also refitted a repaired rad in that which promptly decided to s**t itself again on the way to work today
Beginning to suspect Coolex who did both the re-core and the repair are useless!!!
Anyone tell me what pressure the coolant system usually runs at when up to temp to make sure their pressure testing is adequate?
Re: Body Kit fitted
I can only guess until it's out but it has to be somewhere along the bottom, possibly the join to one of the tanks
Re: Body Kit fitted
Rad out...........again!
Got it down to under an hour now
Re: Body Kit fitted
An hour ? did you drop the engine out 1st
Re: Body Kit fitted
v6 steve wrote:An hour ? did you drop the engine out 1st
I would have
So did you determine that the rad is definitely at fault?
& that your 3.0 has a leaky rad too??
1990 Elan SE Pacific Blue
Re: Body Kit fitted
Yep tHey both have leaks
The 3.2 is a very slow one but the 3.0 is a 'gusher'
Both look like they have failed along the seal between the core and one of the tanks infact on the 3.0, you can see coolant run down the inside seam from about halfway up the core
Re: Body Kit fitted
I didn't think that was too bad for an extremely amateur but determined DIYer
Re: Body Kit fitted
Well the rad is beyond repair, one of the tanks has split
They are ordering a new rad
The only problem is that OE rads aren't available and any other ones don't seem to come with all the relevant hose connectors, I guess whoever nicked the pattern to reproduce them got lazy
They are going to remove the missing connectors from the original rad and plastic weld them in place - only charging me £50 so worth a shot
Re: Body Kit fitted
Almost certain that the HG has gone
Possibly going to have to scrap it sadly but if I do some of the bits will go on the 3.2
Re: Body Kit fitted
doing the head gasket isnt too hard if i was closer i would give you a hand
Body Kit fitted
I know it's not a bad job but it will need the heads skimming to be sure.
Beginning to suspect one of the previous owners was a bodger
It's possible that coolant loss has been going on for a while as the coolant level sensor had been disconnected and bypassed.
Users browsing this forum: No registered users and 55 guests
