some protection to the underside
Re: some protection to the underside
GreyDJ wrote:crinklebender wrote:what a minter...ready for another 20 years.
Im testing a 3 phase corrosion and prevention treatment from US on mine that uses a final epoxy non porous blackseal. touted to be better than Por15 multi-stage treatments.
It is sticky stuff. Normal rust prevention comes of my hands in a few days. This stuff was still there 10 days later.
What is it called?
KBS 3 stage. You can get a small size test pack from ebay which will go a long way. Not enough for an underside though.
http://www.kbs-coatings.com/kbs-three-step-system.html
Im testing it on the impossible. rusty wheel arches, which usually cannot be sorted. Did one arch the regular way: grind, clean, Krust and fill. The other one with KBS six months ago. The KBS one has held up, while the other one is starting to bubble again, wait and see what happens over the winter though.
Looking good, wish i had the time and resources to do mine
saunders wrote:looks clean under there
think someone is trying to get to 50 posts eh
quite common on forums these days ..and its only on ebay links and parts
