Opel Calibra No Fear
Re: Opel Calibra No Fear
Is there no chance you could get a better one from a breakers?
very hard here in Serbia is difficult to find well preserved, and when you find a cost much
Yesterday and today it worked and I'm pretty satisfied, even tomorrow when all blindfolded and place will be good.
So yesterday I'm from the old shelves with front passenger cut a piece of plastic, measure it and made gauge carrier that has the final as a handle ... and outlined the exact location and position and bearings
Today, I outlined the technical saws cut the bracket and made grooves on the console that I barely made because of the awkward position and can not drill with a drill bit just to approach but it worked.
Cropping beds .. and setting gauge
Cutting the groove mount bracket.
Bracket to bracket
job done
Bracket to bracket
job done
Today, we are again done and over again exhaust system.
Mounted mid instantaneous or attached clamps, so it is easy to dismantle as necessary and rear stainless steel also on clamp.
The sound is reduced and pleasant to the ears, I'm tired of yelling and the chromed rear fine on gas.
I did not get to take pictures because we just did and watched it as soon as you're done.
Pictures will be because I have yet to assembled position endings are not exactly as I planned.
There.
There.
