getting my SE6 back on the road bulld/progress thread.
Re: getting my SE6 back on the road build update...
Not a lot has been done...due to being busy at weekends and a holiday in turkey for 10 days lol
Been down the CallyCave armed with a wire brush....so i set about the rear suspension rust...
nasty rear back plate....
Calliper...
Further rust removal will be done before treating/under seal....what do you guys use to treat rust....?
Thanks All
Calliper...
Thanks All
Re: getting my SE6 back on the road bulld/progress thread.
That would probably be a quicker job done over the weekend by removing the rear suspension.
If it were me I'd:
Put it on axle stands
Unbolt calipers, bottom shock bolt, 4x body bolts
Remove rear suspension with wheels attached
Wire wheel it all
Paint with hammerite smooth brush-on (get 2.5L off eBay)
Change bushes as required
Refit
If it were me I'd:
Wire wheel it all
Refit
Easy when u know how!
What's wrong with these?
http://www.ebay.co.uk/itm/2X-VAUXHALL-O ... SwcwhVNBoZ
Chavtastic wrote:That would probably be a quicker job done over the weekend by removing the rear suspension.
If it were me I'd:
Wire wheel it all
Refit
I was thinking about that.....seems the better idea....it's just getting it bolted back up that bothers me mate.
Plus I noticed while cranking the engine the RPM on the gauge don't move at all....New crank sensor.
If it were me I'd:
Wire wheel it all
Refit
What he said!
Calibra SE4 3.2 V6 + F28
A Couple of German Cars!
Awesome pictures there.......Looks like that's the way to go.......if I can grow a set and be brave lol
This is true....I can shot blast small stuff at work...but out new blaster is not big enough.....the old one would have done it....in bits through.
Should the RPM needle move when cranking ?
Mine stays rock bottom.....never moves.
Chavtastic wrote:Paint with hammerite smooth brush-on (get 2.5L off eBay)
I would not choose hammerite. It will peel after some time. There are more robust coatings out there.
POR-15 is more resilient.
1990 Elan SE Pacific Blue
rips wrote:Chavtastic wrote:Paint with hammerite smooth brush-on (get 2.5L off eBay)
I'll use anything I can get my hands on at the moment.....Lol just wish it would start....only if I knew what was the issue and be able to sort it out....need to check the timing marks to rule out the timing belt idea....I'm not too fussed at the moment as the car is safe and dry.
Lol this is true....!
wish u were close tbh
Sent from my C5303 using Tapatalk
I'd leave Nottingham
Chavtastic wrote:I'd leave Nottingham
Lol I would soon track you down....I know your drive way very well due to your parts listings on ebay lol
Bit of an update......While I`ve had time here n there...i goto work underneath....wire brushing and rust proofing...yeh i know its a no runner but its my non runner lol...
Before...it was rusty and was a Advisory on the mot...rear suspension components corroded...not no more....
Before...
After...
Almost down one side....
Took off the side skirt to see if there was any work needed to be done....
[URL=http://s1376.photobucket.com/user/CalibraSE6/media/2016-01-09%2015.07.30_zps9p1wgmeu.jpg.html]
only to find that it was really clean.....now i know from the history that the skirts were removed and replaced by the previous owner as the old ones looks shabby.
Petrol tank straps were removed and shot blasted at work...and painted...
Crusty Exhaust hanger...
After a two min cycle in the shot blaster
Crusty heat petrol tank shield...
In the blaster....
After though...it was a but worse for wear....duel skin heat shield had rusted badly...
rear end....not much metal left.....only just usable....will make a new one asap at work....but for now a few washers will hold it.
New rear brake hoses on order....and copper line and flare kit to go with it....from flexi hose to caliper will be replaced.
Before...
After...
In the blaster....
