CweLibra Turbo.
Re: CweLibra Turbo.
by UndYinG » Wed Jun 04, 2014 3:19 pm
Ordinary maintainance, I've got K&N panel air filter.
Changed polen filter and did AC cleaning.
Got new exide premium batt :)
Image Image
Fitted another fuel filter behind inlet manifold because my fuel hose is too short now :P
Re: CweLibra Turbo.
by EY » Thu Jun 05, 2014 7:44 pm
Transfer box work looks interesting!
Re: CweLibra Turbo.
by UndYinG » Wed Jul 09, 2014 2:57 pm
Clutch began to slip so gearbox was removed
Then modified txb got attached
Washed it and its ready to go back
It will be done next week, im also replacing left engine mount because its broken.
Re: CweLibra Turbo.
by UndYinG » Thu Sep 18, 2014 2:32 pm
I did cheap WG mod by adding old, dirty and rusty spring :). Theres MUCH MORE BOOST now! It went to 1.3bar and i thought it was too much since i experienced slight spluttering. Boost gauge needle was shakey. I was worried so i lowered the boost by adjusting WG. Then i got mail from EDS stating that it should hold 1bar and overboost to ABOUT ~1.3bar on phase 2. Realized i got disconnected vacuum pipe (probably due to higher boost then usual). I secured small pipe and no more spluttering, boosting is awesome and very fun again. It will feel usual in a few months as always, but now its damn fast :).
I've found loose hubs holding the turbo, 2 are missing, im the one who screwed them (if you know what i mean), never thought hubs could get loose. Also missing screws on the exhaust side right on the turbo manifold.
Image Image
Image Image
Then i decided to play with my hood, paint got chipped and i didnt wanna just paint it...
BEFORE AND AFTER
Image Image
Re: CweLibra Turbo.
by v6 steve » Thu Sep 18, 2014 8:38 pm
love the bonnet, Ray wanted to do that years ago but never got round to it looks amazing
Re: CweLibra Turbo.
by John Owens » Fri Sep 26, 2014 1:35 pm
Very smart matey [THUMBS UP SIGN]
Praise the Lowered !
Re: CweLibra Turbo.
by SAMARAI » Fri Sep 26, 2014 2:19 pm
I've never seen such an idea to cover up a dodgy bonnet!
Top effort man. Bonus points for doing something different.
Re: CweLibra Turbo.
by UndYinG » Mon Sep 29, 2014 2:45 pm
Last Friday something got broken, it happened in gear while i was braking. I slowed down and drove for a few minutes very slowly trying first 3 gears. Oil was leaking and later i realized it was gearbox oil. Today gearbox got out and crank is visible. I'm sending it to my friend who has parts and f28 experience and hopefully can replace broken part inside if needed :).
Image Image Image
Image Image Image
Re: CweLibra Turbo.
by SAMARAI » Mon Sep 29, 2014 4:50 pm
Hope you get it sorted without too much hassle man.
Re: CweLibra Turbo.
by UndYinG » Mon Oct 06, 2014 12:04 pm
Screw holding bearing case went for a walk and made a mess, there were 2 holding it to the outer gearbox case. Gearbox is now assembled, I guess tomorrow my car will be out of the workshop.
First picture, screw leftovers and another screws head, then bearing holder placed on the gearbox case, one damaged gear. Last picture is from the internet so you can see how it looks. My friend changed gearbox case and broken parts inside, checked everything else and it seems fine. I never had problems changing gears on high rpm anyway :).
Image Image Image
Image Image Image
Re: CweLibra Turbo.
by UndYinG » Mon Oct 13, 2014 2:29 pm
Last week gearbox got bolted back to its place. My friend disassembled and cleaned everything, it looks good as new :). some pics of his amazing work!
Image Image Image Image
Mechanic broke my txb oil temp sensor :(. I told him to be careful but after 5 times he managed to braeak it. Amazingly he never disconnected it during unscrewing or screwing. Cable got undamaged. Wasnt able to find used one and new is expensive.
I was careful with cutting sensor leftovers and managed to get it out in working condition. Machined new brass screw and assambled it. Drove for about 800km, everything works great!
Image Image Image
Image ImageImage
Met a friend with calibra and made some pictures :).
Image Image Image
Postal service was very gentle with my gearbox so i received it with broken part but it just holds clutch cable direction.
Image ImageImage
Re: CweLibra Turbo.
by UndYinG » Wed Oct 22, 2014 4:14 pm
Re: CweLibra Turbo.
by craigyboy » Thu Oct 23, 2014 10:34 pm
Plenty of good pictures there and that wrap looks amazing
Well done mate. :clap: :clap:
Re: CweLibra Turbo.
by UndYinG » Sat Nov 15, 2014 11:20 am
Thanks, one video of me using appradio
https://www.youtube.com/watch?v=ldtZKIpsQSQ
Changed distributor CAP and ARM with new by Beru. Got dbilas BOV...
Image Image
Remus exhaust
Image Image
Re: CweLibra Turbo.
by UndYinG » Thu Dec 11, 2014 2:42 pm
I have weighted the car today, had about 35L of lpg and 15L unleaded, I've expected exaclty 1500kg which was right, it went from 1500to1520kg! Great weight, factory specs says 1400KG + LPG + Car audio etc. When im in it we become heavy weight :)!1!!
Users browsing this forum: No registered users and 300 guests
