My SE9
Re: My SE9
by caprixpack » Tue Nov 22, 2011 2:53 pm
bit of an update thought it was about time to replace the plastic rocker covers today.
decided it was time to fit the metal cam covers
after a clean and sandpaper painted them
I've never understood why people go over the top with the silicone crap there was more silicone than gasket looks like the previous owner couldn't be bothered to buy a new gasket so just bodged it back together with sealer :roll:
any way scraped it all off cleaned the surface and fit the cover
before
after
only thing that lets it down is the oil filler cap and the old leads time for some magnecores i think
any way time to crack on with the rear one now :alright:
caprixpack
Re: My SE9
by MadOnVaux! » Tue Nov 22, 2011 4:36 pm
caprixpack wrote:I've never understood why people go over the top with the silicone crap there was more silicone than gasket looks like the previous owner couldn't be bothered to buy a new gasket so just bodged it back together with sealer :roll:
It helps them seal, thats why.
Re: My SE9
by caprixpack » Tue Nov 22, 2011 5:12 pm
never had a problem with gaskets not sealing even on my 3 capris i put 2 new genuine gm gaskets on this afternoon no silicone no leaks
caprixpack
Re: My SE9
by Fraz » Tue Nov 22, 2011 6:06 pm
well with the V6 they fit new gaskets and then..............it still leaks!!! due to the plastic covers (usually) so the get out the instant gasket and try to fix the problem ...little knowing teh problem is not the gasket
Re: My SE9
by Allys Cally » Tue Nov 22, 2011 6:18 pm
with the metal cam covers if fitted properly you shouldn't need any extra sealant. mine have been fitted for over 18 months now and no oil leaks so far :D
Re: My SE9
by EddeyDancer » Mon Jan 09, 2012 9:20 pm
Fraz wrote:With the V6 they fit new gaskets, and then it still leaks!!!
Due to the plastic covers (usually) so they get out the instant gasket and try to fix the problem...
Little knowing that the problem is not the gasket
I've carefully inspected both Gaskets of the Plastic and Metal Cam Covers, and can honestly say...
Had the design of the Plastic Cam Cover Gaskets been similar to the Metal Cam Covers, being they have that added base,
then this common 'Cam Cover Leaking Issue' would never have been such a major issue!!!
I've even considered experimenting by grafting a certain section of both Gaskets, but mainly using the Vectra Gaskets...
I'll add more to this and post up some pics to clarify what I mean, very soon!!!
Re: My SE9
by EddeyDancer » Mon Jan 09, 2012 9:21 pm
Just a few things that came to mind, after viewing Your Profile...
I think that these wheels look the best, out of all the ones that were posted in this thread!
The SE9 Calibra looks sort of weird to Me, being that it's without a Sunroof... I've never really noticed this before!
What's that Yellow and White Part? Can You please post up a few photos of where it leads to, on both ends?
Is this Part on all V6's??? As I don't have this on My Calibra V6...
Re: My SE9
by caprixpack » Fri Feb 24, 2012 3:42 pm
well whilst working on my car today the jack decided it had had enough and spat all its fluid all over the drive and went down rather sharpish :shock: luckily i wasnt uder it as i was adjusting the axel stands to go under, but for some reason the air box was :oops: and got crushed by the sub frame :axed:
any way ater much rooting and rumaging around the garage i found an old universal cone filter that i'd bought for an old car lol and some 80mm alloy pipe and trunking, and fashioned myself an induction kit lol and cold air feed 8)
not perfect but will do the job until i get a new airbox
caprixpack
Re: My SE9
by caprixpack » Wed Mar 28, 2012 7:23 pm
Another year another mot passed with only tyre advisories :)
caprixpack
Re: My SE9
by Allys Cally » Wed Mar 28, 2012 9:28 pm
well done mate :D
Re: My SE9
by v6 steve » Wed Mar 28, 2012 9:44 pm
:clap: :clap: :clap: :clap:
Re: My SE9
by caprixpack » Wed Mar 28, 2012 11:04 pm
Replaced the cheapo suspension last weekend with koni items too front and back. Also new rear discs and pads and calipers will get pics up tomorrow
caprixpack
Re: My SE9
by saunders » Mon Sep 17, 2012 7:58 pm
nice work
saunders
Re: My SE9
by caprixpack » Thu Oct 04, 2012 1:59 pm
has been a while now but have recently fitted a magnex exhaust system havent got any pictures of it as yet but itson there lol
caprixpack
