Panda's SE3
Re: Panda's SE3
little update
im picking up some front legs today with new shock's, springs, hubs, bearings, calipers etc another bay bargin
and the plan is .................... oh i cant tell ya yet but i can say that everything is gonna look much better when the wheels are done to match
also the front end is going to get blessed with all new parts and i might even put some -35 springs on the back to level it off
vinny_69
Re: Panda's SE3
well operation front end started this saturday
this weekend (well saturday anyway) i have been hammering my fingers, swearing, grinding and bleeding
this is what i started with
after a bit of grinding and sanding
everything was going well till i started the other side, i couldnt budge the caliper retaining bolts so i decided to cutt em off and then try and get the bolts out
not a happy Panda
so i gave up on one side
and some more shiny stuff to go on next weekend
not a happy Panda
vinny_69
Re: Panda's SE3
you need to get some proper tools then
Re: Panda's SE3
yeah i know
i have the basics a large selection of hammers the trusty halfords 120pc kit brute force and ignorance
but could i get the fecking thing to budge.......... b****** thing
vinny_69
Re: Panda's SE3
so no 10mm allen key socket and a breaker bar then...you need some proper tools if your going to play with cars....spring compressors will be handy for changing them inserts....and a vice or workmate with a BIG set of stilsons
Re: Panda's SE3
the inserts is easy i always use a hammer and chisel
i used the 10mm and a 4 ft bar but that didnt work
so i have two choices really
get hold of another pass side leg and referb it in my own time or take the one off the se3 sand it paint it replace the shock etc all in one day,
vinny_69
Re: Panda's SE3
i did try heat and i did have a good allan key when i started but not anymore
oh well live and learn i suppose
vinny_69
Re: Panda's SE3
well ive got another leg with a failed bearing so i will be sorting that out tonight as we have a press at work
then its game on the weekend painting and fitting shocks and suspension to the refurbed legs and if i have the time fitting em as my poor cally aint too well when it comes to bumps, turning, stopping
i dont think it would last another week
vinny_69
Re: Panda's SE3
i had a good easy weekend
the plan was to take step by step pic's but......
i run out of hand's
thanks to monkey i got another leg but it needed a new bearing and painting, no pics of the bearing being pressed as it was done at work
and a few random ones
see shifty was spot on about my shed
i run out of hand's
vinny_69
Re: Panda's SE3
well i got my arse into gear yesterday and replaced the front suspension and bits
apart from the tracking (i think i forgot the 3/4 turn of the tie rods) everything is Gravy
thanks for the extra hands Rob
as she is now
as she is now
vinny_69
Re: Panda's SE3
Glad to of been some assistance, hope you remembered the big washer from your passenger side
Re: Panda's SE3
And here is the action shot (note for Tazz - no used ones lying around here )
Re: Panda's SE3
yep everything is ready to be tracked in i have tested everything so they best not moan. but the place i use are a good bunch of lads
the tie rod was being a b****** so i just cut it off in the end,and i can report back she is running fine now but everything needs to be nipped up a turn or two as its all settled,didnt think it would take you long to post that one Rob
vinny_69
Re: Panda's SE3
It was burning a hole in my camera
