Few new bits (ongoing)
Just waiting on a new gasket from VX
Re: Few new bits
What's that then?
Re: Few new bits
Mark, what you like aye?
Ive gone for the new top hat as it is a little bit enlarged and also has the dump valve fitting in it, as i didnt want to have it in the engine bay, as i'd have to have the inlet pipe cut/welded.
This way it's hidden under the cover.
Re: Few new bits
It's one of them nasty turbo things, I don't know anything about them.
Re: Few new bits
very nice mate
is that a bailey dump valve?
Re: Few new bits
Much better location for the dump valve. What size intercooler pipework you got, I ended up cutting the first section of the tophat upto the ridge to suit mine, bit less of a restriction too then.
Re: Few new bits
I've got the EDS 2.5"/60mm, with a reducer, so will use that for now, but will get a straight piece later on.
Have you got the Regal/EDS one too? Not very smooth indside are they?
Re: Few new bits
leelee wrote:very nice mateis that a bailey dump valve?
Yes it's a Bailey, bought through LMF, as they are mega cheaper than anyone else i found.
Re: Few new bits
callyman wrote:I've got the EDS 2.5"/60mm, with a reducer, so will use that for now, but will get a straight piece later on.
Yea ive got the same one. Not the best of casting at all, was thinking about getting it smoothed on the inside at some point.
Re: Few new bits
sounds like double dutch to me
Re: Few new bits
Mate of mine had a dig around and found me an old style oil cap, so out came the Autosol and here's the result. What ya think?
Also I got hold of some straight hose and have cut the Tophat back to the larger 60mm diameter so it's now less restrictive.
Re: Few new bits (ongoing)
looking good mate
- Club Member
Polished pipework from TX Autosport at PVS 2010
You may have seen this on the C20LET table they had there.
Users browsing this forum: No registered users and 54 guests
