CweLibra Turbo.
Re: CweLibra Turbo.
by UndYinG » Tue Mar 22, 2016 5:57 pm
I have finally decided to change heat panel that i prepared earlier. Did some modifications and added more white LEDs. Mounted vectra b steering wheel coil, white LEDs in steering wheel wired remote and changed smd resistors with ones that pioneer units recognize.
Disassembling
SMD LEDs
Hot gluing wires into place
Shortend sliders
Testing
Modified vectra b coil vs calibra std coil
Everything fits
Assembling
Got ugliest switch for hazard lights, just to cover the hole. Ima switch that ASAP.
Steering wheel remote LED swap
Removing factory resistors
Soldering SMD resistors with appropriate values and modifying pcb.
Reworking vectra b steering wheel coil harness with calibra connectors on the end.
Everything is back and fully functional
Re: CweLibra Turbo.
by UndYinG » Tue Apr 26, 2016 6:04 pm
I was testing spare CarPC using HDMI on Pioneer AppRadio, turned out to be fully functional! I cant use touch input until i disassemble the pioneer unit, and try some stuff, so ive bought armrest to fit 3D SpaceNavigator with commands i programmed years ago.
Testing the PC
Modifying teh armrest
Old plexiglass holder
Beta version
More armrest mods, it has 7USB ports for charging sharing ONLY 1A. Ive got some 12v 2x2.1A usb charger. Changed SpaceMouse holder angle and painted it black.
Hidding screws and cables
Now we have armrest with 3 front USBs, 4back USBs sharing 2.1A. Other 2.1A port is located inside the armrest, and another USB connected to the PC.
Final position of the armrest, its retractable so it has 2 levels of height.
Ima swap these leds to white ones, one day :). CarPC will be located in the trunk.
Finally removed hood vynil. Got so many new and old scratches so i decided to fill em all :).
Filling
In the end 3 layers of black spray filler and soon ima wrap it in one shiny color, probably glossy black, simple and clean.
Before wrapping it, ima put LE front bumper :)
Re: CweLibra Turbo.
by UndYinG » Mon May 16, 2016 3:28 pm
More armest modifications, screws are well hidden, so only option was to screw center console from underneath the car. Also moved Ipod/iPhone connector for AppRadio
Then fitting the LE bumper :)
Had to cut it a bit and now its symmetrical
Fits perfeclty, i plan on putting 63mm polished FMIC pipes in the future.
Preparing and glueing rear skirt by MyDesign*****
Wrapping with cheapest black gloss wrap :) not so shiney but will do the job for short term use, better then my old damaged paintjob for sure.
More pics
Painted door handles and side trims
Image Image Image
Image Image Image Image
Washed it up
I need to move rear exhausts and get LE side trims and put other rims...
Re: CweLibra Turbo.
by UndYinG » Sat May 21, 2016 8:01 am
Thanks guys!
Ive changed amp to RF Punch 200 DSM so i spent few hours making this :)
More sanding below...
In the meantime, ive moved rear exhausts and wrapped numberplate lights
After more sanding came black carpeting and its done :)
Re: CweLibra Turbo.
by UndYinG » Tue May 24, 2016 1:14 pm
Few gargy approved 300rsd 'n' less certified program modifications.
Smoked side repeaters
Gearbox and handbrake cheap "leather"
Re: CweLibra Turbo.
by UndYinG » Fri May 27, 2016 2:30 pm
Wrap made me nervous, not so glossy and visible scratches all around.
Today car went to visit a car painter. I disassembled it and its gonna be done soon. Its gonna be metallic with hard clear coat Cromax CC6400
Image Image
I almost went for this color
Image Image
But its gonna be different, nothing special but i never seen it on a calibra...
Re: CweLibra Turbo.
by UndYinG » Wed Jun 15, 2016 2:24 pm
Thanks maan!
In the meantime ive been sorting interior
Painting preparation
Base color
Clear coat
Putting it back together
Visited my friend and my other turbo :)
18s were too big and not by my taste, took 17s :)
Then we visited SerbianCalibraDay, more pics here http://postimg.org/gallery/2l4f17nze/
Visited my friend, again and changed the accumulator bulb. Now i need to assemble the interior
Re: CweLibra Turbo.
by UndYinG » Mon Jun 27, 2016 4:12 pm
2 mini meets
ImageImage Image
Preparing pillar covers
Image ImageImage
Mounted front grill, opel logo and rubber underneath
ImageImage Image Image
Image Image ImageImage
Astra g connectors with bulb holders
Interior, speaker and CarPC assembly
ImageImageImage Image
This is where i am now, need to sort out tng LED and button...
Interior is much brighter now, i like it...
Re: CweLibra Turbo.
by ClubCalibraSerbia » Tue Jun 28, 2016 8:30 pm
An awesome job! Great car in every aspect!
It was great pleasure to see her in new outfit, also driving together a few kilometers on highway two weeks ago. :character-beavisbutthead:
Best wishes my friend!
Re: CweLibra Turbo.
by Mark1 » Tue Jun 28, 2016 8:36 pm
Looking good
Sent from my SM-G925F using Tapatalk
Club Treasurer
Club Treasurer
Re: CweLibra Turbo.
by craigyboy » Tue Jun 28, 2016 10:32 pm
Excellent work,well done :clap: :clap:
Re: CweLibra Turbo.
by UndYinG » Tue Jul 12, 2016 4:45 pm
Thanks guys!1!!
Finished side trims and i sanded edges of this lip. CarPC is mounted in trunk now, i just need to redo the carpeting :)
Image Image
host images
Lip has 3m doubleside tape so its easily removable if it gets bored
Had some troubles with radiator hose, it was my mistake because i had to cut it and then it was wide to fit on radiator, put narrower one first, it held for about 500km, then i oredered new one.
This was my fix, silly me...
Spark plug cap came back, powdercoated in red, have to sand and polish the fonts. I need to order red silicone hoses but i never get to it...
Re: CweLibra Turbo.
by chargerbandit » Tue Jul 12, 2016 7:09 pm
Awesome Calibra, how they should be done. Shout out from Slovenia to Serbia!
Re: CweLibra Turbo.
by UndYinG » Thu Jul 28, 2016 3:33 pm
Thanks Bandit :)
Ive been traveling a lot last 20 days, in the end of my trip ive got small hole on one of the turbo coolant hoses. Not a big problem, i got home and had to remove the turbo. Made new hoses, this ones gonna last a loootttttt...
Image ImageImage
It was running high temp with 4 persons, ac and luggage so i went back to factory radiator, XE chinese one was not so nice. Did some cutting on the bumper, sponge and shim, now FMIC has more air. It was rought cut, bumper needs a rework, number plate will stay in the middle but i might move it to the left and get more air trough fmic n stuff...
Image Image ImageImage Image
Finaly got 55mm rubber hose to remove those narrowings ive had to the tophat. Temperature is fine now but didnt have rough contitions, driving up the mountain with 4 peaople in the car, with ac on summer 40degrees day :). Also got new coolant bottle.
Changed water bar with metal one but have no pictures, money well spent since it failed few times on my last calibra...
This is how it looks fully loaded without me in the car, low and not slow :)
Re: CweLibra Turbo.
by UndYinG » Thu Sep 15, 2016 5:16 pm
Another meet with my friend
Image Image
Finally finished CarPC install, added 2 coolers and overclocked it, i will change plexiglass soon because i drilled cooling holes by hand :)
One CREEPY, behind the scenes
One xenon bulb went out so ive bought 2 new, same as old ones 4300k. Changed headlight wiring, with relay holders, everything is soldered and insulated with heat shrink tubes, i was outta tape in the end, will sort wires soon but thats just the looks :).
ImageImage Image
Took some new photos :)
