Continuing the Se2 Turbo!
Well i got the car about a month ago from V6Steve, and i am loving it!! Ive had some issues with the 4x4 and boosting problems but im very close to getting these sorted! Heres a couple of pics from today
Some nice white Wolfrace Pro Lites, really set the car off!!
And a nice powdercoated white rocker cover courtesy of Chavtastic, and some stainless rocker bolts, alongside the stainless afm to turbo hose i put on a while back! Also with my temp mod of the spring on the actuator stolen from my tractor at work
I am just waiting on my power boost valve coming now, should be here monday, need to 100% make sure im getting the right fuel pressure!!
Re: Continuing the Se2 Turbo!
Yes. It will look good, just give me time to get some other bits in there to ccompliment the white
i know where its coming from ill wait till the bay is finished before i say, but love the wheels
Wheels look good
. Why are you getting a power boost valve?
lookin good bugger to keep white multispokes clean have fun best presented ardrossan
Well i have a small update on a nice purchase i just got this evening!!
This will be going on tomorrow, along with the uprated actuator, gear linkage, and fuel pressure regulator! Oh ill be a busy boy!
But well happy with finding this steering wheel! n
yes unless you bodge the light to come on then go off again
or just turn the light off? why would the light need to come on if theres no airbag. Early calibras with no airbag... surely the light dosent come on?
but yours has one, when the mot man turns on your ignition it should come on then turn off after so many seconds its the same with your abs light
and they have a chart shown them what years of cars have a airbag and what the check light should do
I shall just keep hold of the steering wheel, an take the bulb out... 1 years time ill put the wheel back in if it fails... job done
thats what i would do, just remember when you put it back on youll need to reset the light
Yea, thats a vauxhall job aint it?
or if your handy with a soldering iron and your abs works solder the points for the airbag to the abs light
done this a few times to cover up abs problems by wiring the abs light to the airbag light
that sir is VERRRRY clever!!!
