A little job over the weekend
Noticed a bit of rust had returned whilst looking under the car during
the week,so i've cut it out and getting it welded tomorrow.Also replacing
the rear springs and renewing the cv joints
Re: A little job over the weekend
looks like the drain pipes from the sunroof have came out at some point letting water into the wheel well
I checked the drains and they are in the proper position.I think it is just
a common fault on the make up of the calibra as it was the same bit needing
repaired on the se6
repaired on the se6
got the welding done yesterday by my mate john think he done a better job than any garage could do , he fabricated the pieces in his workshop.
gave it a coat of galvafroid paint
then two coats of hammerite and seam sealed it at the back and inside
fitted the new rear springs and a lick of paint!
Good job !
1997 your calibra?
1997 your calibra?
[quote="Phill"]I like the griffin on the caliper Craig.[/quote
Cheers Phil, I got them off ebay
mic43 wrote:Good job !
1997 your calibra?
1996 the car is mate.The rock salt they put down
in winter plays havoc with the cars bodywork
Users browsing this forum: No registered users and 46 guests
