Changing sump
Changing sump
My oil level light has been coming even though the oil is never low
I was advised to take off the sump and clean the switch.I got another
sump from Phil cleaned it up and gave it a few coats of paint
heres a picture so far.
Re: Changing sump
Good work mate
Re: Changing sump
Looking good mate
, I had the oil light come on after about 30 ish miles on the old engine. When i removed that sump from it, there was a lot of thick gunk covering the sensor and all round it.
, I had the oil light come on after about 30 ish miles on the old engine. When i removed that sump from it, there was a lot of thick gunk covering the sensor and all round it.Phill.
Changing sump
Excellent work Craig ! It's a shame though that not many people see all the hard work & upgrades you've done on your cars underside . At least you spoil the MOT inspector lol
Praise the Lowered !
Re: Changing sump
Phill wrote:Did you use the force to levitate the sump for the picture
Forgot to tell you Phil,i'm in the magic circle
