Help needed engine spec
by thomas.fedyszyn » Mon Aug 04, 2014 6:24 pm
Hi I am new to c20let was wondering if some one can shed some light on this spec and wat bhp the engine gd for any help be grateful tom
THE SPEC IS AS FOLLOWS:-
COS-CAST C20LET
MAHLE PISTONS
UNDER PISTON OIL JETS
Z20LET RODS
ESCORT COSWORTH T34 TURBO (FULLY REBUILT)
TIAL EXTERNAL WASTEGATE (1 BAR SPRING FITTED, WAS PLANNING ON CHANGING WHEN CAR WAS BEEN MAPPED)
STAGE 3 ECU
FRONT MOUNT INTER-COOLER
WALBRO FUEL PUMP
XE INLET CAM
1.9MM COMETIC
NEW VALVE STEM OIL SEALS, SHELLS, GASKETS AND PISTON RINGS
SARD ADJUSTABLE FPR
NEW SPORTS CLUTCH
STAINLESS TUBULAR MANIFOLD
Re: Help needed engine spec
by Chavtastic » Mon Aug 04, 2014 11:03 pm
Power depends how much boost you run.
At around 300bhp you are risking your conrods breaking (not a big risk but they are a weak point in your spec). This is more linked to revs, so avoiding high revs will help.
by Phill » Mon Aug 04, 2014 11:18 pm
Welcome to cc.net :)
Users browsing this forum: Bing [Bot] and 30 guests
