Eddey's V6 - The Stocky...
Coolant Leak - Oil Cooler Top Plate GM 90 501 955
by EddeyDancer » Sat Nov 18, 2017 4:52 pm
ACTIVITY UPDATE: 12 NOV 17 @ 111,300 Km
Just when all seemed to be going well, having fixed the two coolant leaks just a week ago, another leak sprung up...
From what I could see, I suspected that the Oil Cooler Top Plate sealant gasket, must have deteriorated...
So as I started stripping it down to the Oil Cooler, my suspicion was almost confirmed...
The Oil Cooler Top Plate was seriously corroded... Lucky I had a spare, in stock...
I removed the Oil Cooler to check on it's condition, and it certainly needed some cleaning up...
The Oil Cooler Well, was drained of coolant, in order to prepare for refitting and resealing of the Parts...
I suspect that the previous owner had changed the Oil Cooler, as an Upgraded Version Oil Cooler was fitted...
The area was cleaned up, and the Oil Cooler was refitted and the replacement Top Plate was fitted using Red Gasket Sealant...
The Lower Manifold, lower gaskets were very compressed, so they also needed to be replaced...
The previous Engine Work that I had done was @ 84,905 Km = 26,390 Km distance travelled...
The Middle and Upper Manifolds were then refitted to the correct specified torques...
Everything else was put back together, and the car sat 24 hours, for the sealant to cure..
24 hours later, I fitted a New AC Delco Oil Filter, topped up on Oil (15w 40) and Coolant (Nulon Type A - 6 year or 500,000 Km)
It started up first go, and sounded much more healthier... I took it for a Test Drive, filled up on Fuel and added a bottle of Valvoline Injector Cleaner...
One thing that I've noticed over the last few days, is that the Engine Temperature rarely goes over 95 degrees now...
by Cliff » Sat Nov 18, 2017 6:39 pm
I’ve heard it’s a pig of a job so hats off to you. How long did it take? Any problems with the oil feed pipes?
by EddeyDancer » Sun Nov 19, 2017 10:42 am
Cliff wrote:I’ve heard it’s a pig of a job so hats off to you. How long did it take? Any problems with the oil feed pipes?
Seriously, in my opinion, it's NOT that bad of a job... 8 Hours all up, of Top Quality workmanship... I'm a Perfectionist...
I just took the relevant photos, not every single detail... I have more detailed pics, earlier on in this Profile...
Fuel Filter Replaced & Rear Wheels Balanced...
by EddeyDancer » Fri Nov 24, 2017 6:49 am
ACTIVITY UPDATE: 24 NOV 17 @ 111,795 Km
I finally replaced the Fuel Filter, and I wouldn't be surprised if the one that got replaced, was the Original Part fitted in 1995...
When I blew into it, heaps of black stuff came out... It's certainly made an immediate noticeable impact, when I accelerate...
I also got the Rear Wheels Balanced, gave them a good clean up, and lubricated the wheel bolts...
I'm really glad that I cleaned up the Rear Wheels, as I also noticed that the Rear Brake Pads, are very low 2mm...
That's the next thing to do...
REPLACED K26 RELAY & REAR BRAKE PADS
by EddeyDancer » Fri Dec 22, 2017 10:04 pm
ACTIVITY UPDATE: 23 DEC 17 @ 112,525 Km
Got the Rear Brake Pads replaced, just in time before the Festive Holidays...
Recently I was having issues with the Cooling Fans staying ON for way too long, after switching the V6 Engine off...
This situation got worse gradually, then to the point where it started to fully drain my battery...
After doing some research, the K26 Relay (Grey) was replaced, and no more dramas..
INTERIOR BULBS REPLACED
by EddeyDancer » Fri Jan 26, 2018 10:40 am
ACTIVITY UPDATE: 26 JAN 18 @ 113,478 Km
I was feeling a bit motivated, and decided to replace the blown Heater Control Panel Bulb...
I also replaced the LED bulb that I fitted in the centre ashtray, cigarette lighter area...
Now all is matching, and looks more complete...
by Cliff » Thu May 10, 2018 6:59 pm
Not seen you in a while Eddey, any updates?
