getting my SE6 back on the road bulld/progress thread.
Re: getting my SE6 back on the road bulld/progress thread.
by sealeysonic » Sun Jan 10, 2016 10:18 pm
v6 steve wrote:looking good mate keep at it
Thank you.
by STEVA » Mon Jan 11, 2016 12:14 am
Doing a cracking job there bud. :D
VXR8 Sting Red 6.2 V8 now 600bhp with added boost!!!!
Calibra SE2 project
by sealeysonic » Mon Jan 11, 2016 5:56 am
STEVA wrote:Doing a cracking job there bud. :D
Thank you....my arms ache today lol happy days.
by sealeysonic » Tue Jan 12, 2016 11:14 pm
What's the best was to find part numbers for my calibra I need links or part numbers for......timing belt....water pump.....aux belt with aircon.....I never know if I'm looking at the right part
C20ne late type engine.
by rich30mex » Wed Jan 13, 2016 1:49 pm
sealeysonic wrote:What's the best was to find part numbers for my calibra I need links or part numbers for......timing belt....water pump.....aux belt with aircon.....I never know if I'm looking at the right part
If you just ring autovaux or the dealer quote your reg number they should find the right parts for you mate
Calibra l,e number 4
by Allys Cally » Wed Jan 13, 2016 7:41 pm
and if he was a full member he would have got discount on it as well
by sealeysonic » Wed Jan 13, 2016 9:49 pm
Lol that's 3rd on my bucket list lol
by cal16v » Wed Jan 13, 2016 10:54 pm
Nice job sealy... I know how tough it is to work in limited space. Keep up the good work.
by craigyboy » Thu Jan 14, 2016 10:11 pm
Well done mate,its always a nightmare working on the car in a tight space.
by sealeysonic » Fri Jan 15, 2016 10:00 pm
craigyboy wrote:Well done mate,its always a nightmare working on the car in a tight space.
This is true and being 47 its a last time effort lol
Some New bits that came in the post.....Genuine GM rear flexi hoses two for a tenner.....and sub fame bolts...thank you Stephen Davies for the bolts.
Re: getting my SE6 back on the road bulld. Update 28/2
by sealeysonic » Sun Feb 28, 2016 9:52 am
Hi all....got my "serious head on" the other day.....Turned my attention to the Crank/no start on my C20ne.......took off the crank pulley to check the timing.....
Top TDC with tippex on the timing mark not by me(belt was changed 10k ago)
Timing mark on the crank sprocket
Now it all needs a clean to confirm.....but it looks like the belt has slipped.
by sealeysonic » Sun Feb 28, 2016 1:52 pm
Gave the area a clean today....
Im still sure the timing marks dont line up.....but all i have to go by is the tippex on the crank sprocket...there dont seem to be a real mark like on the crank pully.
Back of the pully
The rear timing cover has seen better days tbh
The question remains......if i take it all off(which needs to be done anyway)...reset the timing...will it be ok...?
Thanks all
by sealeysonic » Sun Aug 14, 2016 11:30 am
Sorry ive not been on here for such a long time....plant of "stuff going on" as per useual.....bit of an update then.....kinda getting there of the underseal.......
Set about the rear brakes.....gave the caliper a shot blast at work....came up ok....let the shoes in as im raplaceing them.
Got this bugger out too...
bit of a paint....
Now for the back plate.......and we all know this is going to get messy lol
To my deight all the bolts came out fine...
a quick tap to get the bit to sit tight....
clean up time....
The slot where the Yoke goes through
Brace n Bracket.
Shot blasted at work...
Omaga pass side back plate...£25 off ebay...some of you know where im going with this...?
I had hoped to drill out the spot welds to so i can rotate the dust shield.....but the omega plate is not built that way...the Ring the shoes sit on is separate....
thinking time lol
So off to work.....and the Band saw......
Clean the edges up....
Silver bolts to hold it together while spot welding it
Now...while im at it.....time to try can re-produce a back plate to sell on to you lot lol off to the foundry to try a "bench mould" casting.
Not too bad...the plate part needs to be thicker to "run" better....also i knocked the mould out too early.
Worth a try......so I`ll keep at this idea.
Now as im so random when i go down the CallyCave ive started on the timing belt....as no matter how much i try the TDC`s dont line up....
Im hoping this is why i have a crank and no start issue lol
Got this TDC finder tool to play with....it goes in cylinder one and gives you a indication of tdc on compression stroke.
Off with the cam pully....to get to the thermostat housing...where my water leak is coming from....
As you can see there is a fair bit of crap and corrosion...so the leak might have been dripping for ages and just boiling away.
the thermostat housing......not in the best of condition.....there should be a seal here...there was no evidence of anything...no bits of rubber etc...
No2 in the top of this picture..
The rear timing cover shows more signs of leakage...and is brittle as egg shells
A shot blast at work...and good as new...almost.
Apart from what seems to be a crack.....
It goes up and around to the top bolt hole...
Now i have found a new one on ebay...but its £88 so plan B is to see if it can be fixed...so i pasted some Chemical Metal around the crack...sanded it back a bit and a bit of paint...just to see how that goes....
So this is where we are at....lots of random goings on.....lol
by Cliff » Sun Aug 14, 2016 9:17 pm
Looking good Mark, hopefully you have fixed the weep and can get the timing set up again!
by sealeysonic » Mon Aug 15, 2016 9:04 am
Cliff wrote:Looking good Mark, hopefully you have fixed the weep and can get the timing set up again!
thank you....its a long term W.I.P but im happy i still own her.....plus its only got 81 thousand miles on the clock.
Users browsing this forum: Majestic-12 [Bot] and 3 guests
