Calibra v6 3.2 engine transplant
by Jackos-se9 » Thu Jun 25, 2015 11:31 pm
After years of searching have finally today took delivery of a Y32se, 3.2 engine from am omega elite covered a genuine 87000 miles would appreciate any advice on what's going to be involved.
Will post some pictures ASAP
Re: Calibra v6 3.2 engine transplant
by DanSE4 » Fri Jun 26, 2015 9:19 am
As said above, that's pretty much all there is to it (didn't need to swap the sump in my case as I fitted a Z32SE).
I also did thermostat, timing belt & waterpump while the engine was on a stand (so much more pleasant to do that way).
I did fit an F28 with mine though, never did get on with the F25 so if funding permits I thoroughly recommend it. There's a bit extra to do in order to accommodate the F28 & a few parts needed but I can provide details of that if that's something you're interested in.
Calibra SE4 3.2 V6 + F28
A Couple of German Cars!
by Jackos-se9 » Fri Jun 26, 2015 10:18 am
Thanks for the advice not able to fit F28 as it's going into a rare Se9 auto Will post some pictures ASAP
by Callyman » Fri Jun 26, 2015 10:19 am
Typical, my mate has one for sale.
Andy - The Membership Guy
Ceramic Blue 4x4 Turbo
Best Engine bay VBOA 2010, 2013.
Best in show VBOA 2012.
Best Ice VBOA 2014, 2015.
Chairman's Choice PVS 2016.
Best Presented VBOA 2017.
Memberships / Admin
Memberships / Admin
by Mark1 » Fri Jun 26, 2015 6:50 pm
2 pedels II :D
Club Secretary
Club Secretary
by Jackos-se9 » Fri Jun 26, 2015 9:27 pm
Heres the 3.2 im putting in asap just wondering happens with the stainless water pipe coming out of the engine just above crank main bearing in picture 1 ???
by Jackos-se9 » Fri Jun 26, 2015 9:32 pm
Going to start stripping inlet manifolds etc sunday and get it down to the bare engine.
by Jackos-se9 » Sun Jun 28, 2015 10:04 pm
Started stripping engine down, coming apart nicely
by Jackos-se9 » Sun Jun 28, 2015 10:13 pm
Got down to the oil cooler to find the reason the original car (Omega) was broken, failed oil cooler which i was informed of this problem when i originally bought the engine, pop a new one in problem solved.
Will be replacing both head gaskets, water pump, etc anyway
Got new GM water pump ready to be fitted, going to clean the thick mayo type substance left from the failed oil cooler
by Mark1 » Sun Jun 28, 2015 10:16 pm
That is a pig to clean up, good luck with it.
Club Secretary
Club Secretary
by Mark1 » Mon Jun 29, 2015 7:01 am
Washing powder works, we need it to Baz's V6 and it cleaned it all out.
Put it in the header tank when the engine is running and keep changing the water until it is clear.
Club Secretary
Club Secretary
by rich30mex » Mon Jun 29, 2015 9:02 am
Lol pmsl
Calibra l,e number 4
Events Coordinator
Events Coordinator
by Mark1 » Mon Jun 29, 2015 9:06 am
Not going to get it all out until it's running and I know the engines out
Club Secretary
Club Secretary
by Jackos-se9 » Mon Jul 20, 2015 9:36 pm
Off with the heads
Nearly finished stripping engine down
Going to take some putting back together, collected GM parts so far
New stainless oil cooler,
New water pump
New GM tensioner come from Germany
Any advice or help greatly excepted.
by HOT-ROD » Mon Jul 20, 2015 9:57 pm
Sorry if I'm being a bit stupid or missed something but are you replacing a v6 with this one or is this in place of a 4 cyl?
