Bulb warning light
Bulb warning light
by johnny_adidas » Fri May 13, 2005 12:44 pm
Ok the Bulb failure warning light keeps coming on when i turn on my lights(the bulbs are all fine). i tink its down to the lexus lights(black not crapy silver ones hehehe) and the dual filament bulb instead of the separate brake and rear light bulbs in the standard clusters. is there a way to fix this using resisters? and if so how?
johnny_adidas
by warby » Fri May 13, 2005 1:07 pm
had the same problem when i fitted mine easy to fix and you have the right idea if you run a wire off your side lights (1 wire from from each ) then join them together a run the wire to the back of your boot light you will run a new earth with is easy and problem solved this light will come on we you turn you side lights on with will pull enough feed for the warning light to go off.
hope this helps need anymore info just ask:D
warby
by johnny_adidas » Fri May 13, 2005 2:37 pm
thanks mate. ill ad this to my list of tings to fix at d weekend
johnny_adidas
by johnny_adidas » Fri May 13, 2005 2:44 pm
sorry didnt get what u meant at d end of the message. wire both new wires from side lights to boot light and then run a new earth from the boot light? guessin this is to stop the boot light frying yes? wud this work to power any light just as long as it draws away the power that is setting off the sensor. hmm possible leds over amp??
johnny_adidas
by Mac » Fri May 13, 2005 2:47 pm
Not sure I get what you mean??
Earth from each tail light- (connect) Run a single wire from this to?? Back boot light?
I not sure which light you mean mate can you clarify please?
Mac.
Mac
by warby » Fri May 13, 2005 6:27 pm
i know what you mean yes it will work but best to use that kind of bulb it can take being on 4 a long time and its an easy place 4 it 2 go
warby
by warby » Fri May 13, 2005 6:34 pm
and to answer macs question it run off the live wire of your side lights join it up then connect it to the boot light the run a new earth of the boot light to a good earth and there you go problem solved no more bulb warning light,
and you all ways could do what i did get another light from the scrap yard and fit it in you boot and wire that of the wires new disconected from the back of the boot light , so you still have a light when you open your boot
warby
