V6 alarm -do they have em?
I have a 96 N reg 2.5 V6
THe thing that bothers me is there is no remote central on it nor is there an alarm system - is this correct - if not can anybody tell me where the bits will be hiding on the car, so I can check the previous owner hasn't relinquished them of there duties
Cheers peeps
niggy0
Cheers peeps
niggy0
niggy0
To test it, when you lock the door right round to deadlock position, the red light should light above the passenger side door on the sensor should light for 30 seconds and then start flashing, if it flashes its armed
To set it off, pull the bonnet cable, leave the bonnet closed, lock the car up and wait for the light to flash (after 30 seconds), then open the bonnet, the alarm should sound, to turn it off unlock the drivers door
ROG
Robbie, you are mistaken. The immobiliser is in the ECU and deactivated when you start the ignition. There is chip in the Key which allows the Immobiliser to be deactivated and the receiver for the chip is around the ignition barrel. It's not the type of immobiliser that you deactivate by way of a key/button etc.
jaybv6
Mine has both.
