Oil /volt gauge
Oil /volt gauge
by jusser » Sat Jul 16, 2005 2:55 pm
Hi - I've managed to wire in my gauge in my cally but after wiring in the illumination cable to the green/grey wire in the stereo iso loom I find that although the gauge lights up it doesn't dim with the dimmer switch.
Is there such a wire will do this on the iso loom or do I have to go behind the instument binnacle - and if so where is the wire and what colour will it be?
cheers
Jusser
jusser
by joeraz » Sat Jul 16, 2005 4:57 pm
sorry i cant answer your question but i am about to change the standard gauges for indiglo ones, do you know what the 4 wires are on the loom,, i hav looke at the haynes wiring diagrams but am none the wiser
joeraz
by jusser » Sat Jul 16, 2005 5:24 pm
Have a look here
<a href="http://homepage.ntlworld.com/cavweb2000/pix/gauges.jpg" target="_blank">http://homepage.ntlworld.com/cavweb2000/pix/gauges.jpg</a>
jusser
by joeraz » Sat Jul 16, 2005 10:50 pm
cheers for that but i dont actually get it,, i would hav thought that the battery volt would be a more direct to battery connection,, and im thinking the screw terminal feed is the oil pressure signal,, hmmm,,, think i will pass to a pro! lol
joeraz
by jusser » Sun Jul 17, 2005 11:16 am
The screw terminal is the oil pressure signal! - it goes into the screw terminal of your (hopefully) 2 output oil pressure sender.
If you connect the live direct to the battery you will have to fuse it with a 30amp (I think) fuse, and whilst this will give a truer reading it will not be a switched live so it will be on all the time.
jusser
by Fraz » Sun Jul 17, 2005 1:08 pm
for the gauges lights to dim its best if you use the clock (or D.I.D or Fuel Computer...what ever you have) wiere for the light , that dims with the wee wheel dimmer thing
IIRC I wired the actual voltage wiere to the back of fuse 9 , but a lot have just used the lighter feed wire
the oil gauge needs the oil switch changed to the duel type sender and then a wire run from the gauge to the new sender unit
