*urgent* Alternator Fault Maybe
by Robert_Dale » Thu Aug 25, 2005 10:14 pm
Cheater, cheers for the advice but its still blowing the fuse
right symptoms:
Fuse number 2 keeps popping (speedo and cigerette fuse) this in turn causes the battery light to come on!!
this seems to happen when i rag the car (not reving but driving fast)!!
tried putting a 30amp fuse in (only one i had) and now the battery light is on constantly and seems to flutter a bit!!!! also the fuse gets REAL hot!!!
so the volt reader reads a steady 14volts or whatever and seems to be working ok.....now is the alternator knackered or could this be something else.
whats the best way to test.
16v Redtop L Reg
Rob
Robert_Dale
by Cheater2k » Thu Aug 25, 2005 10:38 pm
mine blow when i was doing 1/4 miles sprints, in the rain, useing wipers, radio, heated windscreen etc.
it could be the alturnator, but im sure ATS etc can check this for free anyway to make sure its ok, or any good car electrition [img]/smile.gif[/img]
Cheater2k
by Robert_Dale » Fri Aug 26, 2005 8:31 am
Cheers Cheater, anyone else experienced this fault???
Robert_Dale
by BazV6er » Tue Aug 30, 2005 12:14 am
rob ,
when i joined clubcalibra .com (cough!!) my alternator died one night just as i was getting back from the chippy ,it turned out i had to get an reconditioned one for £90 approx as (manfred had told me a diode had burnt out and as it turns out he must of been right cos the new one has been great for the last 2 yrs
by SukySaggi » Wed Aug 31, 2005 1:21 pm
Don't put in a bigger fuse, as this could lead to smoking wires / fire. Get your alternator checked out and take it from there.
SukySaggi
by FatLadZ » Thu Sep 01, 2005 9:36 pm
if you start your engine and then disconnect the negative wire off the battery the car shouldnt die if the alternator is working.
just an easy test to see if its shot
fatz
FatLadZ
Users browsing this forum: Majestic-12 [Bot] and 28 guests
