rear foglights, fuse blows everytime
by tox » Fri Jan 13, 2006 9:58 pm
Hi mates
I have rear foglamp on the left side, everything is wired, i have the button in the dashboard, but everytime i want to light it, the fuse blows. How can i check if the switch is broken or it's another fault. Note that the front foglights work like a charm, and according to the Haynes manual, rear and front foglights share the same relay in the fusebox. Please help
tox
by turbo83 » Sat Jan 14, 2006 3:41 pm
i've got the same problem but mine is witht the front, rear is fine but front blows, i've changed switch, relay, fuse and nothing i'm lost
turbo83
by pr0xZen » Sat Feb 04, 2006 6:55 am
If the fuse blows every time you engage the light, there is definately a short. reading turbo83's comment here leads me to believe it is either somwhere in the taillight, or in the wiring between this light and the relay.
pr0xZen
by dj_smurph » Sat Feb 04, 2006 1:22 pm
best think to do will be to rewire the feed from the relay to the light
dj_smurph
