Trip computer - Switch problem
by pr0xZen » Fri Mar 17, 2006 2:12 pm
Sorry to bump a really rusty thread, but I'm stuck here.
I've finally got the FC, but the buttons came from a carlton. A 5-lead ribbon cable comes out, all leads gray except the one wich has a black line on it. Anone got a wire diagram on how to pull this one off? Can't just chop and solder without this as all the wires are the same color.
If anyone got color-coded wires, could they post a pic of the underside of the buttons - where the wires meets the print?
pr0xZen
by chief » Tue Mar 21, 2006 11:24 pm
think the wires are numbered on the plug
chief
by pr0xZen » Tue Mar 21, 2006 11:56 pm
Indeed they were. wired up with spades and labeled the leads for any future work.
pr0xZen
by Animal » Thu Mar 23, 2006 7:12 pm
Can a carlton one be made to fit then?
by pr0xZen » Fri Mar 24, 2006 2:52 am
Yes they can. The input/output/pin numbers are printed on both plugs. The pin layout dont match but the numbers are the same.
In case you are of the unlucky ones without wiring for the plug/ecu - you'll find the wiring for the plugs in the Haynes manual: 12x47, lead 351-355:
Pin 1: BRSW (Brown/Black)
Pin 2: BRRT (Brown/Red)
Pin 3: BRBL (Brown/Blue)
Pin 4: BRWS (Brown/White)
Pin 5: *Blank*
Pin 6: BRGE (Brown/Yellow)
You might have guessed from the schematic, 6 (B/Y) is common. Could be useful to know if someone decides to mod them up with LEDs.
pr0xZen
by tobys73 » Fri Mar 24, 2006 5:40 am
thanks m8 just what i needed got my comp & switch on ebay for £8.50 but the switch was a carlton one so the diagram is helpful
tobys73
