A few little niggles with my V6!
by simonV6 » Fri Apr 14, 2006 1:46 pm
Been poking around it today after getting it last night and a couple of things which are bugging me.
1: ECU and ABS light comes on now and again, Everything seems to be running fine etc and just had new discs and pads all round.
2: Elec sunroof is not working, Fuse is fine and the windows work but sunroof doesn't do a thing.
3: Traction Control button doesn't do anything, surely it should turn it on and off but nothing at all.
Cheers :thumb:
Si
simonV6
by Rusty_CallyT » Fri Apr 14, 2006 2:30 pm
<!--QuoteBegin-simonV6+--><div class='quotetop'>(simonV6)</div><div class='quotemain'><!--QuoteEBegin-->1: ECU and ABS light comes on now and again, Everything seems to be running fine etc and just had new discs and pads all round.<!--QuoteEnd--></div><!--QuoteEEnd-->
Do they come on together? if they do it might be a bodge behind the clocks to look like sommits working when its not
Rusty_CallyT
by simonV6 » Fri Apr 14, 2006 3:50 pm
<!--QuoteBegin-Rusty_CallyT+--><div class='quotetop'>(Rusty_CallyT)</div><div class='quotemain'><!--QuoteEBegin-->Do they come on together? if they do it might be a bodge behind the clocks to look like sommits working when its not<!--QuoteEnd--></div><!--QuoteEEnd-->
No they come on whenever they feel like it, sometimes together sometimes just the1.
Just been out in it for an hour and none of them came on. :freak3:
simonV6
by Tim2001 » Fri Apr 14, 2006 3:59 pm
TC button turns the traction control off. To test if its still working without touching the button move the car away from a standing start as per traffic light gp. Bring the car to a stop press the button and try it again. If its working you will notice the difference. When you turn the ignition off it always resets to working.
Tim2001
by simonV6 » Fri Apr 14, 2006 7:16 pm
I dont get any lights up on the dash though.
Shouldn't it tell me if its on or off??
simonV6
by Dan_85 » Fri Apr 14, 2006 7:46 pm
the TC light will only stay lit if you have switched it off!
should flash when it's on and it's actually doing something! like if you hit the gas a little too hard [img]/wink.gif[/img]
Dan_85
by Stig » Thu Apr 20, 2006 8:42 pm
does the light come on when you switch the ignition on?
Stig
