Temp Gauge not working
Hi Guys,
The temp gauge in my cally has stopped working. The engine isn't over heating and the fan is cutting in when the cally has been in traffic for long periods so I presume everything is ok, Can anyone tell me where the sensor is so I can check it and does anyone have any ideas as to what it could be?
Star_Silver_XE
As above, the wire has a spade connector which is easily pulled off. Touch the wire onto the engine block or another earth, this should send the temp gauge needle up and off the scale, if so it's the sender thats faulty, if not it's the wiring/connectors/gauge.
